Testing Time
We followed our standard case testing methodology, as detailed in our
previous heatsink and case testing article, and fitted the usual set of hardware into the Cooler Master HAF 92, doing our best to hide and tidy cables to ensure as few airflow restrictions as possible. Here's a reminder of the hardware we use.
CPU: Lapped Intel Pentium XE 955 (dual-core, 3.46GHz)
Graphics Card: Sapphire Radeon HD 3850 Ultimate passive cooled
Motherboard: MSI P6N SLI Platinum
RAM: 2x 512MB Corsair XMS2-667
Hard Drive: 1x 250GB Western Digital WD2500 7,200RPM
Heatsink: Asus Silent Square Pro
Power Supply: Xilence XP700 700W PSU
While this isn't representative of current ultra high end hardware, the equipment we use is specifically selected to kick out the maximum of heat inside the case, with a passively cooled graphics card and 130W TDP processor at its core to really heat things up and push the case's ability to cope with toasty components to the limit.
With its impressive cooling array of three 230mm cooling fans and large use of mesh rather than flat panels for the front, side and roof to allow for improved passive ventilation, we were expecting some pretty impressive results from the HAF 932, although we certainly weren't expecting what happened next...
Cooler Maser HAF 932
Akasa Omega - all fans
Zalman GS1000
Hiper Osiris
Akasa Omega - stock fans
Lancool K7 Metal Boned
Lian Li Tyr PC-X2000 - high fan
Akasa Mirage-62
°C
Ambient
Case
CPU
GPU
Load Delta T (CPU)
Cooler Master HAF 932
Zalman GS1000
Hiper Osiris
Akasa Mirage-62
°C
Idle
Case
CPU
GPU
CPU Delta T (load)
Akasa Omega - All Fans
Zalman GS1000
Hiper Osiris
Akasa Mirage-62
°C
Ambient
Case
CPU
GPU
GPU Delta T
